amildm
Contributor
4 years ago[SignalTap] copy/paste/duplicate signals + seeing the same signal in several groups
Hi All,
1) Is it possible to add the same signal to SignalTap Waves Tab several times (e.g. in Questa it's possible)? Purpose - convenience in viewing the signals. The signals in my SignalTap ...
- 4 years ago
No, run-time triggers are standard Signal Tap instance that run when your design is running in hardware. A power-up trigger is a child instance of a run-time trigger that lets you capture trigger events that occur after device programming but before you can open the .stp file and click "Run Analysis". Right-click a Signal Tap instance in the .stp Instance Manager to enable it.
SyafieqS
4 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
