17 years agoSignal Tap II analyzer error
Hi, I am using Quartus II for Cyclone II device. I have USB blaster for JTAG connection. I am trying to use signal tap II analyzer. When I try to recompile the file, after setting the in...
17 years ago --- Quote Start --- Thanks a lot for replying Pletz. I found the mistake. I had installed both quartus 7.1 and 8.0. Signal tap II analyzer was pointing to 7.1 but i had compiled my program in quartus 8.0. --- Quote End --- Hi, fine that you found the root cause. I expected something like that. Switching between Quartus versions requires always signaltap files, generated by the corresponding Quartus version. Kind regards GPK
