skyviper
2 years agoSignal Tap clock in trace window
Can someone tell me how to add a reference clock to the trace window (data window)?
sstrell
2 years agoThere is no need to tap the sampling clock because each sample represents the rising edge of the sampling clock. You can add cursors in the output waveform to count the number of samples between events, representing ticks of the sampling clock.
Signal Tap should not be used to solve timing issues because it only shows what's happening at the rising edge of that sampling clock. The Timing Analyzer is for high speed timing analysis.
