skyviper
2 years agoSignal Tap clock in trace window
Can someone tell me how to add a reference clock to the trace window (data window)?
ShengN_altera
2 years agoHi,
You can add the clock signal to the signal tap data window but you can't if the same clock signal had been used for Clock: in Signal Configuration.
- skyviper2 years ago
Why is that the case? You can't see the signals referenced to the clock to see if there is a timing issue. In step 5.3 of the Four Hour FPGA Lab it asks to answer the following questions. How can you answer these questions without the clock in the trace?
