11 years agoshort between Gnd and +5 volt in DE0
Hi ..
i have altera DE0 Kit when i was working on the project i shorted between the gnd and +5v on the pin expansion out and the kit want work after this short !! :\ is the kit damaged !! :\ http://www.alteraforum.com/forum/attachment.php?attachmentid=10554&stc=14 Replies
I think it probably is damaged, yes. I'm afraid that is a difficult lesson learned the hard way. Look after your hardware!
Regards, Alex - Altera_Forum
Remove all custom connections.
Check if 5v voltage regulator is gone and replace it if doesn't works. - Altera_Forum
--- Quote Start --- Remove all custom connections. Check if 5v voltage regulator is gone and replace it if doesn't works. --- Quote End --- which on of those ? and can i test it on the board ? http://www.alteraforum.com/forum/attachment.php?attachmentid=10566&stc=1 - Altera_Forum
thx bro but it work fine with the adapter
