11 years agoshort between Gnd and +5 volt in DE0
Hi .. i have altera DE0 Kit when i was working on the project i shorted between the gnd and +5v on the pin expansion out and the kit want work after this short !! :\ is the kit damaged ...
11 years ago --- Quote Start --- Remove all custom connections. Check if 5v voltage regulator is gone and replace it if doesn't works. --- Quote End --- which on of those ? and can i test it on the board ? http://www.alteraforum.com/forum/attachment.php?attachmentid=10566&stc=1
