12 years agoShifted clock signal when connecting to FPGA (cyclone iii)
Hello, I am getting some strange behavior that I can't understand what would be causing the behavior. I have a 32MHz crystal oscillator that I've been trying to use as a digital clock signal to drive...
12 years agoThank you for your reply. Could you direct me to a handbook/user guide on how to use the pll properly (or global clock) that is generated via a dedicated input clock pin? I looked into the Timing Wizard in Quartus but I wasn't sure if this is where to look to generate the PLL output.
