14 years agoSharing memory: Nios and HDL-module
Hi All! I need to share SRAM between nios II and HDL-module. What component I need in SOPC? I have a hand-made component Bridge to SRAM (MM slave- MM tristate master) and MM Tristate slave comp...
14 years agoYes, you are correctly understood.Sory for my English:)
I have created SOPC-component of Master Avalon-MM with conduit input (like DMA-controller). My master need to hold a bus (same as DMA-controller). What signal I can use for holding bus? lock? I can't find documentation witch explain arbitration on Avalon bus. I known only about AN184 (extras.springer.com/2001/978-0-306-47635-8/an/an184.pdf). Thank you.
