19 years agoshared memory with nios
Hi, I must use NIOSII with external asynchronous SRAM memory...but i must shared this memory with my IP...somebody can help me?I don't know the way to start... many thanks
19 years agoYou can use the tris-state bridge component that connect to the external asyn. SRAM. Both your CPU and IP can now access the external asyn. SRAM through this tri-state bridge. Check the reference design provided under the nios2eds/example directory.
