14 years agoSGDMA in loop-mode
Hi all!
I know that there are allready a lot of SGDMA-Threads posted in the forum, but it seems that I have a special problem regarding this IP. I like to use SGDMA in loop-mode, meaning that I have four descriptor-chains jumping from one to another and starting again with the first descriptor after the fourth by setting the PARK-bit. Everything works fine when I tell the SGDMA the exact amount of data to be transfered (Stream to Memory), but if I tell the SGDMA that every transfer should last until EOP is received, by setting length_or_eop to zero, the "TERMINATED_BY_EOP" error-bit is on in the descriptor status-byte after every transfer. Maybe Socrates had a similar Problem, when he posted that an error-bit got up, when he wanted to use the loop-mode, in the very interesting thread titled "SGDMA debug". So, does anybody know if this is a general problem of the SGDMA-core? Or is there anything else I could do? Thank you in advance for your help!1 Reply
O.K., I found another mistake in my Code which prompted the SGDMA to hang.
It seems that it is normal, that the "TERMINATED_BY_EOP" error-bit is on after every transfer, when using the SGDMA transfering until EOP. It also seems that the error-bit has no effect on the DMA-process itself and can be ignored in this case.
