15 years agoSFL Production System
I am using an EPC40 in AS mode with an EPCS16 flash device. Our design is complete and works as expected when programming directly to the AS device. Now for our production environment we are tr...
15 years agoDid you follow the procedure in the application note to create the second .jic and .jam files? You must be sure that the generated jtag indirect file goes through the SFL. From what you are describing it seems that the .jam file that you use is wrong and just configures the FPGA, just like the first one (the one that places the SFL in the FPGA).
