15 years agoSFL Production System
I am using an EPC40 in AS mode with an EPCS16 flash device. Our design is complete and works as expected when programming directly to the AS device. Now for our production environment we are tr...
15 years ago --- Quote Start --- You should then see a new component in the JTAG chain which is the EPCS flash. You can then use the Quartus programmer to upload your design in the flash. --- Quote End --- Yes the autodetect works and I can see the EP3C40 with an EPCS16 tagged off it. If I try and assign an image file to the EPCS16 entry it will only let me add a JIC file, I want to add the SOF or JAM. I am probably doing this wrong because it seems odd that it only limits me to a JIC as this file type already has the SFL integrated which defeats the object of pre-loading the SFL in the FPGA.
