14 years agoSEU ref. design and map of care/don't care bits
Hello
Recently I read a White paper with title Robust SEU Mitigation with StratixIII FPGAs. In this paper, it is said that StratixIII FPGA has a hard logic CRC Engine that employs a 16-bit CRC value per CRAM frame for SEU mitigation. If a CRAM error is detected by the circuitry within a frame, CRC engine pulls high the CRC error pin, so appropriate action must be taken, such as reconfiguring the FPGA. Also it is mentioned that a critical error detection capability is implemented in soft logic using a reference design that is supported from Quartus II 7.2 onward. The operation of the critical error detection solution is as follows: 1. Detect and locate the configuration soft error using the built-in soft error detection circuitry. This asserts the CRC_ERROR pin. 2. The soft logic then takes the error information and uses it to calculate an address within a file containing a map indicating which configuration bits are “care” or “don't care.” 3. Using a user-specified memory interface, such as the active serial configuration port, the soft logic then accesses the appropriate bit in a sensitivity map file to determine if the particular configuration soft error is critical to the design currently configured into the FPGA. 4. If the configuration soft error is a “don't care,” then the FPGA can continue operating without a functional error. If the configuration soft error is a “care” and may be affecting functionality, then the CRITICAL_ERROR pin is asserted and the appropriate action can be taken within the system, such as reconfiguring the FPGA. The file containing the map of “care”/”don't care” bits is automatically generated by the Quartus II design software for a particular design according to resource usage and the utilized routing.my question is where could i find the soft logic "critical error detection" reference design and also what extension has the map of “care”/”don't care” bits which is automatically generated by the quartus ii software. Thank you in advance. Dimitris Agiakatsikas
1 Reply
Answer received from Altera :
I checked in database, there is no such design example on this soft logic "critical error detection". The reference design available on this CRC Error Detection is from the following link: http://www.altera.com/literature/an/an539.pdf http://www.altera.com/literature/an/an539_design_example.zip
