9 years agoSetting VCC on MAX 10
An old VHDL design is being ported to a MAX 10 device (10M2DCU324C8G). It is to run in a 3.3V system. The Quartus Prime Lite compiled it and assigned pins but it configured all the pins to 2.5V (defa...
9 years agoYou can set all pin related assignments in the Pin Planner in the All Pins list at the bottom without having to use the Assignment Editor. If you do not see the I/O standard column, right-click in the All Pins list and enable the column.
