9 years agoSetting VCC on MAX 10
An old VHDL design is being ported to a MAX 10 device (10M2DCU324C8G). It is to run in a 3.3V system. The Quartus Prime Lite compiled it and assigned pins but it configured all the pins to 2.5V (defa...
9 years agoUnder the 'Assignments' menu, select 'Pin Planner'. Here you can specify the I/O standards for all your I/O.
Alternatively, you can change the default I/O standard for your project. 'Assignments' -> 'Device', then select 'Device and Pin Options...'. In the 'Voltage' category change the 'Default I/O standard'. Cheers, Alex
