8 years agoSetting up PCIe Connection Cyclone V
Hello, I am trying to set up a Cyclone V FPGA so that I can configure the core image through a PCIe connection. As far as I understand it, I need to create a .periph.jic file to upload to the FPGA fi...
8 years agoHi,
--- Quote Start --- Is there any way I can successfully program the board using USB Blaster II through the USB mini port on the FPGA --- Quote End --- Yes, you can use USB Blaster II. Check below link for steps to configure the flash device. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/rm_cvgt_fpga_dev_board.pdf https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_cvgt_fpga_dev_kit.pdf --- Quote Start --- Can't recognize silicon ID for device 1 --- Quote End --- Default board setting is FPP change it to AS mode. https://www.altera.com/support/support-resources/knowledge-base/solutions/rd02112014_88.html CVP user guide. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_cvp.pdf May be because of following- 1.Configuration device selected incorrectly while generating .jic file.
- 2.TCK clock frequency you can change the frequency(From Nios II command shell) and try.
