18 years agoSetting up a 25Mhz PLL
I have a PCIe Stratix II dev Kit. I need a 25Mhz clk out. My understanding is that the FPGA can provide a clock out (using the 100 MHz on board internal clock) by setting up a PLL. If this is correct, how do I go about doing it.? I have no idea on how to set it up. Any help will be appreciated. Thanks in advance.1 Reply
You need to create an ALTPLL instance that will create a PLL in your design. The PLL will accept your 100MHz clock as input and produce a 25MHz clock as output.
From Quartus II: 1 - Tools->MegaWizard Plug-In Manager. 2 -Create a new custom megafunction variation. 3 - Select the I/O category on the left. 4 - Then select the ALTPLL megafunction. 5 - Give your file a name and click next. The megawizard will launch. Read the documentation if you need to. At the end of the day you'll have a verilog or vhdl module that you can instantiate in your design. Jake
