12 years agoSetting i/o pins to tri-state mode.
I am a newbie. I am using a board with a Cyclone II, To prevent the board from getting excessively hot, I need to set all I/o pins to tri-state mode. How do I do that?
In Quartus, with your project open, go to 'Assignments' -> 'Device'.
Click on 'Device and Pin Options'. In the left tab select 'Unused Pins'. Reserve all unused pins 'As input tri-stated' - (with or without bus-hold/pull-ups as necessary). Cyclone II projects seem to default to 'As output driving ground'. Good for noise immunity, not particularly appropriate for development boards. - Altera_Forum
If FPGA is configured with a "bad" design, to prevent excesive hot, you can temporarly pull down (1k resistor) the nconfig pin usually pin# 5 on Active Serial connector.
Thank you so much for helping this poor soul.
Andrew
