9 years agoset_input_delay And set_output_delay .SDC Constraints
Hello! I have little familiarity with the set_input_delay and set_output_delay SDC and was wondering whether the following commands would correctly constrain the inputs as per the requirements in th...
9 years agoI think I might know what's happening here.The two clocks are shown because of the I2C configurable latching(rising edge or falling edge for single latching mechanism).The diagram here shows dual latching (on both rising and falling edges), it basically latches twice per clock cycle, which is why the tS and tH are labelled as they are.I think the diagram just says that in the 1 ns around any edge(0.5 ns for setup and 0.5 ns for hold), the data should remain constant if the dual latching mechanism is used.
And yet again thank you for your patience and help! :)
