9 years agoset_input_delay And set_output_delay .SDC Constraints
Hello! I have little familiarity with the set_input_delay and set_output_delay SDC and was wondering whether the following commands would correctly constrain the inputs as per the requirements in th...
9 years agoI understand the register------>comb------>register part.But, kindly answer me this :
1) Let's say that at t = 0, we have a rising edge on the clock. 2) The external device outputs data at 26ns (TCO max). 3) Question : Will the IO register(the one that has to read the value at the input pins) latch this value at t >= 26 ns? If so, this value becomes available in the FPGA at t >= 26ns or (26/37) of the clk period? Would it not be better to add another register(cascade/series) that stores the value at the next rising edge? Doing so would use up one clock cycle though. This scheme is only for the input/output from the FPGA. Thank you!
