11 years agoSet configuration with PS mode by other MCU
Hello, I have some problems with PS mode configuration. I used to use AS mode as configuration solution for years. And this time , I want to config the FPGA with other MCU with PS mode. ...
11 years agothanks for the reply.
I tried the .rbf file, and it works , too. The .sof and .rbf both work well in download cable with PC. I changed byte of .rbf and I found the waveform changed, too. I am convinced that sending all data into the FPGA will config the FPGA well. There is something odd among the waveform. The CONF_DONE raised before the last byte of .rbf was sent. It's different form the document. Anyway, I think I can take care of the last. Thanks for the help.
