billmax's avatar
billmax
5 years ago
Serial Flash Loader IP not working with A10 and EPCQL512
I'm using EPCQL512 with 10AX115N2F40 in a known good hardware design. Quartus Prime 20.1.1 Quartus Programmer & USB Blaster What works: Creating a jic file encapsulating a factory SFL image work...
  • billmax's avatar
    5 years ago
    When comparing the behavior of the factory SFL image and my design with SFL IP added I still don't understand why the attached serial flash shows up in a JTAG scan with the factory image loaded, and not in a scan when my design is loaded.
    However, after deciding to assume that the SFL in my design otherwise works and testing JTAG access to serial flash (such as doing a flash verification operation without having to first load the factory SFL image) the SFL IP does appear to bridge JTAG and ASMI.
    I create and load a jic file as usual, then uncheck the box for configuring the factory SFL image prior to flash access. My design remains loaded in the FPGA, and I can verify or load the flash without disturbing FPGA operation.
    So it works for my purposes, although with a minor quirk of not being able to detect the flash presence via a scan.
