16 years agoSerial configuration problem of Cyclone II device using quatrus 9.1
I have a working design implemented in a Cyclone EP2C5T144C7 device conficgured by an EPCS1 prom in Active Serial mode.
I switched to Quartus 9.1, recompiled the project, and reprogrammed the EPCS1 with the new pof file, all without errors. Now the FPGA configuration never completes. In other words, it never finishes reading the prom after the power is cycled - it just keeps sending clocks. I am assuming that there is some option that I have to explicitly set someplace to make the pof file behave as before, but I cant figure out what it is. Many thanks in advance for any advice!! Mats Selen, University of Illinois15 Replies
In case I wasnt clear, the programming files produced with earlier versions of Quartus for this same design have all worked perfectly fine.
check whether you have activated Compressed Bitstream Option for the programming file. Seems there is something broken in v9.1 as deactivation of this option generates working pof files. (Had same issue with my EP2C8 and EPCS4...) Sincerely, Carlhermann - Altera_Forum
Thanks very much for the reply!
I have checked the "generate compressed bitstreams" box in the "device and Pin Options" Configuration tab. Is there some other palce I need to specify this as well? The odd thing is that all of the obvious device options seem to be the same the same as they were when I was using V9.0 SP2, which worked great. Mats - Altera_Forum
I had also not changed anything between v9.0 SP2 and V9.1 and encountered same problems which disappeared by un-checking " Generate compressed bitstreams" (config file is now uncompressed and things worked out fine again). I think this was never intended by ALTERA but sometimes wired stuff happens... CU, Carlhermann - Altera_Forum
I tried doing that first - the problem is that my design doesnt fit into the configutation prom when I turn off the compression :)
Do you think Altera is aware of this issue or is it worth reporting it somehow? My hope is that they know and it will get fixed in the next version. I think I will just go back to 9.0 for now - it works fine for what I'm doing. Thanks again for your help!! Mats - Altera_Forum
well - they should be aware of, as this already has been reported some posts ago in the forum and I also had a support request on this. We could hope, they'll fix it in SP1. As part of my service request, ALTERA gave me a workaround (if you need both, v9.1 and compressed *.pof): * generate uncompressed bitstream * start manually File => Convert Programming Files * Select your's project *.sof and check "Compression" (select *.sof and Properties) * check the “Disable AS mode CONF_DONE error check” option from the Bitstream Generation Advanced Option Utility (Advanced) This generates a compressed file, that configures the CycloneII, but for me this would be too much manual work and I think I'd revert to v9.0 SP2 in case I would need a compressed file too (my Hardware EP2C8 and EPCS4 works fine w/o compression) CU, CS - Altera_Forum
Thanks - have a great holiday.
Cheers MS - Altera_Forum
hi,
I use EP2C5Q208 and config device is EPCS4, and assembled with the " Generate compressed bitstreams" option checked. My project can work well! - Altera_Forum
I have exactly the same problem : EP2C20 project builds with V9.0sp2 and no problem configuring, builds with 9.1 and device doesn't configure.
I did notice that the assembler report file with 9.0sp2 has "Info: Active Serial Mode CONF_DONE pin error checking is disabled", but that's not there in the 9.1 rpt file. So far, I haven't found what this means and if/why this mode became enabled in 9.1, or how to disable it. It's a pretty glaring testing failure - mainstream devices just won't configure with the new version.....oh well, I guess that's the price we pay for the new "pastel shades" in the splash. - Altera_Forum
hi,
I mistaked it. My project can run well only with sof. The pof can only run well without the " Generate compressed bitstreams" checked.
