16 years agoSerial configuration problem of Cyclone II device using quatrus 9.1
I have a working design implemented in a Cyclone EP2C5T144C7 device conficgured by an EPCS1 prom in Active Serial mode. I switched to Quartus 9.1, recompiled the project, and reprogrammed the...
16 years agoHi,
this option "Active Serial Mode CONF_DONE pin error checking is disabled" is exactly what you actively set when generating "manually" the pof as I described. Thus it seems this option was deactivated in v9.0 and has been (whatever reason) activated in v9.1 now... Carlhermann BTW.: I asked ALTERA if this deactivation might cause false or incomplete configurations due to noise, ... during configuration not to be detected, but this is not.
