12 years agoSerdes in Cyclone 5 devices
I have implemented a deserializer in Cyclone 5. We see some issues in the final system output (video to a monitor). One of the other engineers here thinks the Serdes in this particular variant (E) ...
12 years ago --- Quote Start --- I may be confusing what "dedicated" serdes logic means. Documentation says Cyclone 5 has dedicated logic. --- Quote End --- That basically means they have a high-speed shift-register hard-IP block. --- Quote Start --- What I'm after is DPA capability. Looks like that is not an option for this device. The document you linked shows that in Dec. 2012, they removed DPA support. --- Quote End --- Ok, I see that same note. The Stratix series devices have DPA. A quick search in the Arria V handbook shows they have it too. If you do not need dynamic phase-shifting, but do need some sort of power-on alignment, you could also consider using the ALTPLL_RECONFIG block and shift the phase of the ALTLVDS PLL (you can configure the ALTLVDS component for external PLL mode). Cheers, Dave
