16 years agosensitivity list. VHDL
Hello, Maybe this is an elementary question, :D. Why I need to add all the signals that I use in a process to the sensitivity list. If I add them or not, I am getting the same results...
16 years agoI am not completely with you about the role of the sensitivity list. For me, it is not only a tool for the simulator, it can also impact the synthesis.
For example, take the following codes. The first process has a sensitivity list with all the signals that are read during the process, and this lead to a combinatorial circuit. The second process misses the b input in its sensitivity list. This implies that if a stays at the same level and b changes, the process is not activated and the output is not modified, so this leads to a latch in the circuit, so the process is no more pure combinatorial.
process(a, b)
begin
if a = '1' and b = '0' then
c <= '1'
else
c <= '0'
end if;
end process;
process(a)
begin
c <= '1'
else
c <= '0'
end if;
end process;
