Sending data to FPGA - Need Help
Anyone know how I can send a 16 bit binary word typed from a keyboard and send it to an input on my FPGA board? I am using Quartus ii and Terasic C1 development board. A gui with an input box and a send button would be ideal I just don’t know were to start any suggestions??
Thanks for the help, Tom4 Replies
In the past, I would use Nios+JTAG with download cable as the communication interface and use nios-console to write in values. Quartus now has features such as In-System memory editor and In-System Sources and Probes. Haven't tried them but I think which help you achieve what you want. Only need a download cable and Quartus.
http://www.altera.com/literature/hb/qts/qts_qii53012.pdf http://www.altera.com/literature/hb/qts/qts_qii53021.pdf - Altera_Forum
Yes, ps/2 is is more fittable to you ,since your requirement is uni-direction transfer
use a ps/2 interface , only simple shift register will do that
Through UART
