15 years agoSending 60 video frames per second using Ethernet
Hello, First of all happy new year. We are designing an embedded system that is used to send video frames to another embedded system via Ethernet connection. It is required to send 60...
15 years ago --- Quote Start --- I miss any information about the involved data amount respectively video coding. Usually video over ethernet deals with MPEG4 or similar encoding. There's an Altera application note about ethernet througput with and without hardware acceleration, you should compare your results with the theoretical values. Apart from these principle limits, there may be problem in your way of accessing the SDRAM. --- Quote End --- Hello, Thank you for your reply. Regarding the video I am displaying, it is my computer's desktop. I am sending what is displayed in certain position on the desktop computer. This video data is sent to Cyclone III reference design board via the DVI connector of the Graphics card. Kind Regards.
