15 years agoSending 60 video frames per second using Ethernet
Hello, First of all happy new year. We are designing an embedded system that is used to send video frames to another embedded system via Ethernet connection. It is required to send 60...
15 years agoI miss any information about the involved data amount respectively video coding. Usually video over ethernet deals with MPEG4 or similar encoding.
There's an Altera application note about ethernet througput with and without hardware acceleration, you should compare your results with the theoretical values. Apart from these principle limits, there may be problem in your way of accessing the SDRAM.
