12 years agoSDRAM on DE0-nano board
Hi, I am still not having any success writing and reading from the SDRAM on on the DE0-nano board from the FPGA. I have built a system in qsys which includes a Nios II and SDRAM controller an...
12 years ago --- Quote Start --- I'm not seeing an error. Just when I write to the SDRAM controller and try and read it back , the value is either 0xffffffff or just the last 8 bits are as expected. --- Quote End --- I'd call that an error :) You don't see this error with the example I gave you, right? Try comparing the top-level design. Perhaps you have made a simple mistake and not connected the ports on your Qsys instance correctly. Does the Quartus messages window have any weird looking messages? --- Quote Start --- To do a simulation, I need to create some testbench? --- Quote End --- Yes, but first try tracing the RAM access using SignalTap II. Cheers, Dave
