12 years agoSDRAM on DE0-nano board
Hi, I am still not having any success writing and reading from the SDRAM on on the DE0-nano board from the FPGA. I have built a system in qsys which includes a Nios II and SDRAM controller an...
12 years ago --- Quote Start --- I have tested the example in the zip file and and it works fine, so there should be no problem with the hardware. --- Quote End --- Great! Its always useful to have minimal designs that prove your hardware works. --- Quote Start --- Going back to the SDRAM controller in Qsys, I have changed the refresh rate and power-on delay as you said but there is still something wrong. --- Quote End --- In what respect? What error are you seeing? What you have done seems reasonable. The Qsys system inserts width adapters, so the fact that your JTAG master is 32-bits and your SDRAM interface is 16-bits should not matter. Whenever I see a problem in hardware, I first look at the problem using the Signal Tap II logic analyzer (which you can add to your FPGA design), and then I use a simulation to duplicate what I see in the hardware. Try those tools and see how far you get. Ask questions when you get stuck. Cheers, Dave
