12 years agoSDRAM on DE0-nano board
Hi, I am still not having any success writing and reading from the SDRAM on on the DE0-nano board from the FPGA. I have built a system in qsys which includes a Nios II and SDRAM controller an...
12 years agoHi Dave,
I have now added an SDRAM controller to the qsys design from the jtag-to-avalon-mm example, gave it address 0x0 and assigned all the appropriate pins for the DE0-nano SDRAM with pin-planner. In the jtag_cmds_sc.tcl script , I have added extra code to "talk" to the external SDRAM on the DE0-nano as follows :
proc sdram_write {offset data} {
global jtag
if {!} {
jtag_open
set addr
master_write_32 $jtag(master) $addr $data
return
proc sdram_read {offset} {
global jtag
if {!} {
jtag_open
set addr
return
When I then try to write from the tcl console with command "sdram_write 0 0x12345" for example and read it back with "sdram_read 0" , I am only reading 0x00000045, hence only the lower 8 bits seem to be written everytime. What would be the issue here. Is it something with the tcl script or my SDRAM controller settings? In my SDRAM controller settings , the data width is set to 16 bits , chip select :1 , banks: 4 Under address width , Row : 13 , Column : 9 Thanks, Paul
