12 years agosdram controller
Greetings Gentlemen! So I've been using SRAM for the longest time but I'm kinda at a point now where I want *MORE*. Unfortunately, this also means PAYING more so I'm kinda forced to use SDRAM. ...
12 years ago --- Quote Start --- Alright, after having perused various datasheets, I have a (perhaps) obvious question with regards to clocking and latency. Let me see if I can phrase this correctly: Given a certain clock frequency, you can calculate how many clocks you'd need in order to satisfy timing requirements. For example, a tRCD of 15ns at 100mhz would imply 2 clocks, which would give you 20ns and therefore meet the timing requirements, whereas a 200mhz clock would imply at least 3 clocks. These figures are all listed in the datasheets as well as the timing in nanoseconds. --- Quote End --- --- Quote Start --- My question is whether or not SDRAM needs to be clocked or if you just need to satisfy those timing requirements. In the example above, you could either wait two clock periods or, if you would lower the clock speed (I know, different discussion) to say, 25mhz, you could submit two commands back-to-back as there would be ample time to satisfy the timing requirements. --- Quote End --- Being SDRAM with the 'S for Synchronous' clocking is quite elementary ... The Cas-latency is specified in clocks and is minimum two (2). In theory at very low frequnecies this easily could be lowered to one (1) but I guess that the manufacturers (primarily JEDEC) didn't see the use of this so it can not be specified either. --- Quote Start --- So I guess to sum it up, are commands and data (in/out) the only ones that need to be clocked or do you NEED to clock in NOPs as SDRAM is a synchronous, pipelined architecture? -Mux --- Quote End --- Yes you clock in NOPs, but this is automatic as a NOP is the absence of any other command.
