14 years agoSDRAM Controller Full Page Burst Error
Hello everyone:
I have designed an SDRAM Controller that allows burst writes or reads of 1, 2, 4, 8 or 256 (Full Page). Now, I am testing this controller and everything seems fine except for the full page write. When I test a full page write, the first value written is exactly the same as the last value, for some strange reason I can't understand. I have used SignalTab, but according to the results I obtain, the first value being written is what it is supposed to be. However, when I read the first value written in the SDRAM, I get the last value. This happens only with the full page burst, because burst writes of 1, 2, 4 or 8 work fine. I will give you some information, that might be useful: - I am working on the Altera DE-2 Development Board. - SDRAM is ISSI IS42S16400D -7TL ABR13400FH 0622. - I am using a 100-MHz clock for the SDRAM controller, and a 100-MHz clock with a phase shift of -3ns for the SDRAM clock (recommended for the DE-1 board, so I am not sure if this phase shift is appropriate for the DE-2). - I am writing pseudo-random values using a LFSR to test the SDRAM. The first value is 0x0001 and the last value is 0x3E03 (no relation at all). - If I write the 256 values, one by one (burst length = 1), there is no problem. Same goes for burst lengths of 2, 4 and 8. Thank you in advance for any help.1 Reply
I found the problem looking at more sdram datasheets. The full page burst read/write doesn't self-terminate (wraps around), so you need to issue a burst stop command.
I hope this information might be useful to somebody.
