19 years agoSDR SDRAM Controller
I use SDR SDRAM Controller to control SDRAM. The port looks like follows:
--inputs: signal az_addr : IN STD_LOGIC_VECTOR (25 downto 0); signal az_be_n : IN STD_LOGIC_VECTOR (7 downto 0); signal az_cs : IN STD_LOGIC; signal az_data : IN STD_LOGIC_VECTOR (63 downto 0); signal az_rd_n : IN STD_LOGIC; signal az_wr_n : IN STD_LOGIC; signal clk : IN STD_LOGIC; signal reset_n : IN STD_LOGIC; --outputs: signal za_data : OUT STD_LOGIC_VECTOR(63 downto 0); signal za_valid : OUT STD_LOGIC; signal za_waitrequest : OUT STD_LOGIC; signal zs_addr : OUT STD_LOGIC_VECTOR(12 downto 0); signal zs_ba : OUT STD_LOGIC; signal zs_cas_n : OUT STD_LOGIC; signal zs_cke : OUT STD_LOGIC; signal zs_cs_n : OUT STD_LOGIC_VECTOR(3 downto 0); signal zs_dq : INOUT STD_LOGIC_VECTOR(63 downto 0); signal zs_dqm : OUT STD_LOGIC_VECTOR(7 downto 0); signal zs_ras_n : OUT STD_LOGIC; signal zs_we_n : OUT STD_LOGIC; My ueser logic reads and writes data via SDR SDRAM Controller from and to SDRAM. I define follow signals for read operation. az_addr <= (other 0); az_rd_n <= '0'; --read enable az_wr_n <='1'; --write disable clk and reset_n signal are also assigned and az_cs <= '1'; az_be_n<="11111111" --data mask disable write operation az_data<="11111...1" -- 64 bits az_rd_n <= '1'; --write enable az_wr_n <='0'; --read disable clk and reset_n signal are also assigned and az_cs <= '1'; az_be_n<="11111111" --data mask disable But I can not get back the data. I don't know if in my assignment somewhere is wrong. I have tried for many times.2 Replies
SDR SDRAM Controller I used exist in SOPC too.
just use the controller in sopc builder, the interface is simpler.
--dalon
