9 years agoSDI over IP
Hi I have already designed and implemented TS over IP (SMPTE-2022-1/2) using Altera FPGAs, 1G Ethernet and external DDR-2 memory. I want to start design and implementation of 3G-SDI over IP (SMPTE...
9 years agoFor TSoIP I have a custom board, designed for broadcast applications. For TSoIP I feed the TS through the Ethernet interface and the extracted TS will be delivered to communication module inside the FPGA.
Raw TS can also be fed through ASI interface. Either an MPEG encoder or a TS player can be used for generating TS source with video content.
