9 years agoSDI over IP
Hi I have already designed and implemented TS over IP (SMPTE-2022-1/2) using Altera FPGAs, 1G Ethernet and external DDR-2 memory. I want to start design and implementation of 3G-SDI over IP (SMPTE...
9 years agoIf you had no problem with Ethernet transmit, the protocol would have no problem?
Did you have any problem with jitter control? Did you require an external memory; i.e. DDR-II/III for smooth output?
