9 years agoSDC for ALTCLKCTRL
Hello, I have an ALTCLKCTRL component implemented in my design targeting a Cyclone V FPGA. The ALTCLKCTRL has 4 of its inputs occupied: 1. Clock_1 driven by an FPGA pin. 2. Clock_2 dri...
9 years agoThere's nothing stopping you from doing it. Are you saying that the tool is reporting that the output of ALTCLKCTRL is an unconstrained clock? Like I said, if you have other clocks that don't go through the mux, you would need to create generated clocks on the output of the clock mux as references. The reason you don't need to in your case is that ALTCLKCTRL is not generating a new clock. PLLS do create new clocks based off of other clocks.
But if for some reason the tool is reporting it as unconstrained (which is unusual), then yes you'd need generated clocks as well.
