9 years agoSDC for ALTCLKCTRL
Hello, I have an ALTCLKCTRL component implemented in my design targeting a Cyclone V FPGA. The ALTCLKCTRL has 4 of its inputs occupied: 1. Clock_1 driven by an FPGA pin. 2. Clock_2 dri...
9 years ago --- Quote Start --- Clock creation is for creating essentially reference points for timing analysis, not defining delays. --- Quote End --- Exactly. If I don't use the "create_generated_clock" command on the output of ALTCLKCTRL - how would the tool know that it should analyze timing in reference to that point ? I mean, we use the "create_generated_clock" on all PLL outputs - so why is the ALTCLKCTRL any different ? Why doesn't it deserve a "create_generated_clock" command on it's output ?
