14 years agoSD-SDI transmitter
Hi I have a problem in generating SD-SDI signals. I'm trying to build a SD/HD/3G transmitter by using test pattern generator(TPG), clocked video output(CVO), and triple SDI. The video st...
14 years agoHi Socrates
Thank you for the reply. The SDI transmitter I generate is triple video standards. So the width of input txdata is 20-bit. In my design, I use 2-bit signal tx_std to select a video standard (SD/HD/3G) and which video signals from TPG and CVO is connected to the SDI transmitter (use a MUX).
