13 years agoSchematics to configure Cyclone GX by Parallel Flash Loader (MAX II+NOR Flash Memory)
I am looking for schematics for a stadard solution. I need to configure Cyclone IV GX in PS mode by Parallel Flash Loader residing inside MAX II with configuration data inside NOR Flash Memory. ...
13 years ago --- Quote Start --- In the "Parallel Flash Loader Megafunction User Guide" section "Specifications" on page 46 there are equations to estimate the time for reconfiguring the FPGA with the PFL megafunction. In the Table 15 Ccfg is calculated from DCLK Ratio, but in the following examples Ccfg is always equal to 2.5. Why? Is it an error? --- Quote End --- Lets see ... http://www.altera.com/literature/ug/ug_pfl.pdf The example on p48 starts by stating that DCLK ratio = 2, so the later use of Ccfg = 2.5 appears to be an error. File a Service Request with Altera and ask them to fix their documentation. Cheers, Dave
