13 years agoscfifo output latency
May i know what is the output latency for the SCFIFO operating at normal mode and optimized for area? Refering to the userguide date august 2012, the output latencies are the following: wrreq/rdreq to full:1wrreq/rdreq to empty:1
wrreq/rdreq to usedw[]:1
rdreq to q[]:1
I tried with a simple design using modelsim altera but the output latency for rdreq to full & rdreq to q[] obtained seems to be different from the userguide. My results using modelsim are: rdreq to q[]:0
rdreq to full:0[/B] [/B]
You're welcome!
Cheers, Dave - Altera_Forum
Thank you very much. Its very helpful :-P
--- Quote Start --- May i know what is the output latency for the SCFIFO operating at normal mode and optimized for area? I tried with a simple design using modelsim altera but the output latency for rdreq to full & rdreq to q[] obtained seems to be different from the userguide. --- Quote End --- The user manual has errors. This attached simulation can be used to view the latencies.
Cheers, DaveProcedure to run the FIFO simulations: 1. Unzip altera_fifos.zip 2. Start Modelsim and change directory to the altera_fifos folder 3. Source the simulation script, i.e., source scripts/sim.tcl 4. Run the single-clock FIFO simulation (sim_sc) or dual-clock FIFO simulations (sim_dc) with the desired options; showahead on/off, use EAB/LCs, and output register on/off
