13 years agoscfifo output latency
Hello, May i know what is the output latency for the SCFIFO operating at normal mode and optimized for area? Refering to the userguide date august 2012, the output latencies are the follo...
13 years ago --- Quote Start --- May i know what is the output latency for the SCFIFO operating at normal mode and optimized for area? I tried with a simple design using modelsim altera but the output latency for rdreq to full & rdreq to q[] obtained seems to be different from the userguide. --- Quote End --- The user manual has errors. This attached simulation can be used to view the latencies.
Procedure to run the FIFO simulations:
1. Unzip altera_fifos.zip
2. Start Modelsim and change directory to the altera_fifos folder
3. Source the simulation script, i.e., source scripts/sim.tcl
4. Run the single-clock FIFO simulation (sim_sc) or dual-clock FIFO simulations (sim_dc) with the desired options; showahead on/off, use EAB/LCs, and output register on/off
Cheers, Dave
