18 years agoScaling core clock of 100MHz to 23MHz & 20MHz
Hello All, I am using Altera Stratix II for my project. I have generated a PLL in LVDs mode(for a deserialization factor of 10 and date rates is 1000Mbps). The two available clock sources ...
18 years agoThank you.
Am using a deserialization factor of 10, iRxClk is 100 MHz slow clock which is the output of an external PLL. As you mentoined prevously that you are allowing new data_align pulse after 8 clocks, Could you please tell me which part of your design deals with the 8 clocks? I have modified my code as below but there is no change yet. Data_align : process (iRxClk,inUserReset) variable count: integer:=1; begin if(inUserReset='0') then rx_channel_data_align <= "0"; elsif(iRxClk'event and iRxClk='1') then count:=count+1; if(count=11) then count:=0; end if; if (rx_channel_data_align = "1") then rx_channel_data_align <= "0"; end if; if(rx_dpa_locked="1") then if(count=10) then if (q_lpm = "0100110101") then rx_channel_data_align <= "0"; ready<='1'; else rx_channel_data_align <= "1"; end if; end if; end if; end if; end process Data_align;
