18 years agosampled signal on falling or risins edge?
Hello, I have a beginner question. With the code below The signal in_width_pulse_n is wide of one period (clk_speed) My question is on signal old1_width_pulse_n I must be sampled it ...
18 years agoHello,
Thank for you answer. You can see these signal on attach file. I don’t have problem on the design speed. But though it was not sure sampled signal on rising edge if it is generated on the previous rising edge. I ‘m anxious for metastability problem: sampled signal when it change. What do you think about that moreover if I test my fpga in incubator with a wide temperature range!
