byisrael
4 years agoSame PCB for the two CY4 FPGAs EP4CGX150CF23C8N & EP4CGX30CF23C8N
In order to support one PCB the two CY4 FPGAs EP4CGX150CF23C8N & EP4CGX30CF23C8N,
Need to connect additional I/O pins of EP4CGX30CF23C8N (see below) to GND/VCCINT (1.2V)
I compile EP4CGX150CF23C8...
- 4 years ago
Hi Israel Ben-Yeda,
It is not mandatory. You can refer to the link below for more details about this issue.
When migrating devices that have overlapping I/O and power pins, how...
Aqid Ayman
AqidAyman_Altera
4 years agoHello Israel Ben-Yeda,
If you plan to use those pins as GPIOs, then you may add the resistor and put DNI.
- byisrael4 years ago
I don't need to use those pins as I/Os, so I don't need the resistor?
GX30 IO pin should have no problems connecting to VCCINT?
Thanks & Best Regards,
Israel Ben-Yeda
