16 years agoSafe clock division
Hi all, I've been researching this for a while (because the Classic Timing Analyzer has failing paths) but here's my question: What is the safest way to divide down a clock? Currently I...
16 years ago --- Quote Start --- Does the enable structure remove the clock skew that would be implemented in a ripple counter? --- Quote End --- Yes, it's not clock gating.
process (clk)
begin
if rising_edge(clk) then
-- code executed every clock cycle
if cnt = 15 then
cnt <= (others => '0);
clk_enable <= '1';
else
cnt <= cnt + 1;
clk_enable <= '0';
end if;
if clk_enable = '1' then
-- code executed at the divided rate
end if;
end if;
end process;
