16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
16 years agoHi Jake and Nekojiru,
I was able to fix the issue with the SRAM. It was not an timing issue, but the Alter IP SSRAM core is a pipeline SRAM and the one that I have used is NoBL. Thanks for your help. Kumaran
