16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
16 years agoHi Jake,
Thanks for the information. I am working on the issue with the SRAM being a No Bus Latency(NoBL) device and the Altera IP core being a piplined SSRAM. I will look at the calculation that you provided and let you know the results soon. Thanks a lot for the help. Kumaran
