16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
16 years agoWhat the pll shift value are you using now?
I usually use -1.66ns for the 50MHz ssram clock vs to 50MHz sopc system clock. This setting worked for 4 or 5 different board already. Give it a try!
